Clear IP OSPF Statistics
Use the following procedure to clear all IPv4 OSPF statistics.
Use the data in the following table to use the clear ip ospf stats command.
Variable |
Value |
vrf WORD<1–16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0–512> |
Specifies the ID of the VRF. |
